Success Story of T-Mobile UK flash to 2.2
paulcooper
Apr 19, 2010
266
9
Many thanks to SJamG who wrote this topic
How to Flash / Debrand your Desire
after flashing and 4 OTA updates i just rebooted and i am now running andriod 2.2 on my desire.
Andriod Version
2.2
BaseBand Version
32.43.00.32U_5.09.00.20
Kernel Version
2.6.32.15-gfpc0526
htc-kernel@and18-2#1
Build number
2.09.405.8
Software number 2.09.405.8
Browser 3.1
Think thats it.
Going to scutinise the phone for the next few days now!!
1 - Defo good HD 720p (1280 x 720) the quality is nice.
2 - Speed of the phone and doing thing is better (it was quick anyway)
3 - New sms app is appealing, works very well.
4 - Email (push mail to exchange server 2003) is working quickly and so far likes to
not send emails out of peak time. (given it some heavey testing)
5 - Browser is quick to load and processes pages quickly (using 3g)
6 - wifi is much nicer finds, and uses it quickly. I have 7 routers here and connects
to each one easily.
7 - bluetooth works a lot better with my Parrot carkit ck3200, ALL contacts now
sync with photo.
8 - Battery life seems ok given the amount of hammering it's had from a full charge at
5pm to now at 01:11 it's got 48% left and thats after the upgrade downloads
over wifi (30mb) and playing with it. impressive
9 - Weather shows my town name of Bridlington
10 - Google maps and Navigation works amazingly - seems to render satellite view
quicker.
11 - www.tvcatchup.com works brilliantly due to the Flash 10 player so many
websites work better now
12 - I can now view my own website properly - www.VictoriaHouseBridlington.co.uk
13 - facebook app works so much better and even has an inbox that works
14 - a number of my apps are on the SD-card, they dont install by default to the SD
as you dont get a choice, but you can goto - menu / settings / Applications /
Manage Applications
you can select the app and move it to the sd card - i presume it the app and
not the install
15 - Marketplace works a treat, finds and loads so much quicker
16 - volume of caller sounds clearer and when on speaker phone too - but not the
best, thats hardware not software.
17 - Sky Sports I can now view
http://live.skysports.com/ScoreCentre/football.html so when in town and the
wife is shopping i can check the footy scores live - A MASSIVE IMPROVEMENT
18 - I can do my online banking
19 - all my contacts phone and email have synced from my exchange server
20 - Youtube on 3g is bareable, much better than befoe.
21 - google maps navigation works fine just as expected.
22 - wifi hotspot - turned it on and bang laptop noticed it connected asked for
password (which i had not set) but the desire shows a notification and shows
you the code - simples.
23 - Flashlights as a std app is cool
24 - ebay works well too.
25 - So does msn messenger
26 - marketplace notified me of an update earlier
27 - my emails peak/offpeak time is working correctly
28 - Battery seems to be lasting given the amount of usage i have done.
to be honest a great upgrade - cant say it was a massive upgrade, but a lot has been fixed, fingers crossed
Hope this was helpful people
Still i have no complaints or issues with my t-mobile UK desire on 2.2 absolutley everything works, even my problem with emails coming though out of peak times, which was my only issue with 2.1.
YES I AM VERY PLEASED
BEST TECH IN 2023
Smartphones
