Hi
I'm new to rooting, so I do my trials on my old HTC One S.
I already managed to unlock and root the device.
Currentyl I'm trying to make an app a system app. According to the manuals I read it should be as easy as coping the apk to the /system/app folder and reboot the device.
Unfortunately after reboot, it seems that the system does some kind of reset, as any APK I copied to the /system/app folder have vanished ...
Android 4.1.1
Using:
ES File explorer with r/w access ..
I also tried to use /system/app-mover, but installing the BusyBox fails.
Any clues ?
Android 4.1.1
Using:
Any clues ?
