Root The littlest help would be appreciated
Can't wait for root
I'm already out of Space 72 hours in moving apps to SD or being able to remove bloat would be so helpful even if it can be achieved without root
If you don't use all the Google Apps, a good place to start would be to disable anything you don't use/need in settings>apps>all applications. When you disable, be sure to uninstall updates too. That should free you up a little space anyway. Hope that helps.
