HereticSins
Android Expert
I'm gonna start theming the LG motion little by little till we get recovery. Will be showing how since it requires a bit more work since we have no recovery.
If you guys want a different color just tell me, also what you would like to be themed and ill look into it.
First change just to see if it worked.
Stock Status bar black.
All black notification drawer with minor tweaks.
First rename and remove the stock from stockSystemUi.apk or black from blackSystemUi.apk depending on which you want.
, than just copy and paste the modified SystemUi.apk in /system/app using root explorer and reboot.
Its easy and you won't brick.
Stock UI with black status bar.
http://db.tt/onOmbwGk
All black notification drawer.
http://db.tt/o9JGzDMz
