Help Trying to upgrade to 2.3.5 through Odin
yuvasweb
I've been trying to upgrade my Galaxy S2 to 2.3.5 version through Odin for the past one hour.
I have checked
  • Re-Parition
  • Auto Reboot
  • F.Reset Time
before I started the procedure. However, once it started initializing data.img, there is not much progress :(
For a moment, I was scared whether its been bricked but, there were some forums that suggested Re-paritioning will take lot of time.
Please advise if I need to unplug it (or) let it continue to do its work? (I'm checking whether the phone is getting heated or not often..just to be on safe side)
I'm assuming you followed intra techs thread on xda to Install?
If so then you obviously didn't read the following line in big bold font in the instructions:
5.*DO NOT PUT .PIT FILE AND DO NOT, I REPEAT, DO NOT TICK REPARTITION.
I've never ticked it in the past and not sure what it does so I don't know what the implications are of aborting part way through.
Good luck. Let us know how you get on mate.
