Hello guys first all of all just forthe info Allwinner A10 tablet cant be hard bricked! You can always flash a livesuit.img and restore your tab back! We dont have the original liveusit.img of the tab but i manage to get back on stock with few steps and this method is confirmed and tested!!
Requirements -
ADB Drivers ( ADB_Drivers.rar - 4shared.com - online file sharing and storage - download )
USB Mouse
Little Brain
Note : If you have CWM installed onyur tab you can simply Restore from your restored backup if you dont have one here it is
2012-09-25.11.49.26.rar - 4shared.com - online file sharing and storage - download
Step 1 : - Download the software called Livesuit you can easily google it and find it but here's treat for you!
http://www.yarvik.com/userfiles/yarvikfirmware/YarvikLiveSuit.zip
Step 2 : - Download this image http://www.yarvik.com/userfiles/yarvikfirmware/TAB461EUK_A404.img
Step 3 : - Extract Livesuit software and open Livesuit.exe -- > Whataver pop-ups come just click no! -- > Click on select image and browse to the downloaded TAB461 .img and leave the software as it is
Step 4 : - Now connect your tablet ( make sure it is turned off not in recovery or something , you can do this by holding power button for long ) to the pc/laptop by holding back button! as soon as you attach usb , while holding back button press 'power' button 10 times repeatedly!
Wait and a pop up will come Click 'YES' 2 times it will take 2 mins to flash the image and u will soon boot up!
Step 5 :- Touch wont work on this image! So connect your wired mouse with OTG cable and install CWM and then the backup! as described below
http://androidforums.com/funbook-pro-all-things-root/624776-tut-install-cwm-micromax-funbook-pro-p500.html
If having any problem comment below! i will solve it!
If u like my work....just hit THANKS
Requirements -
USB Mouse
Little Brain
