Hello! I looked for solutions to these problems I'm having but haven't found anything relevant. I actually just got this phone new in October after I killed my LG Optimus Slider. I was frustrated with how slow the Optimus was, but still wanted the $25 per month plan from Virgin Mobile. I tried using CM7 when I first got the phone, but had some problems and went back to the stock ROM. I'm not sure what information will be necessary so I'll just put up some stuff: Android Version 2.2.2 Baseband Version PR5 Kernel version Apps_2.6.32.9-perf Software version 1010_2_039 I also have 622MB available for internal storage if that matters. Most of the time I have WiFi and 3G disabled, and Lookout mobile security running at all times. (I'm paranoid, but lazy about it. I read reviews a long time ago that said Lookout was good, but I don't know if it's still relevant.)
My first problem is during calls, every so often I hear a beeping noise like a number being held down if I was dialing. I'm not dialing when this happens, and if I look at the phone the number-pad isn't even on the screen. I'd have to press the button to bring it up. I remember an old phone I had with Virgin Mobile before had a feature to beep every minute of use, but I couldn't find one for the Triumph. So far I've only noticed it with long distance calls, but none of the calls I make to local numbers are very long. It might not mean anything.
The second problem I'm having is that 1/3 to 1/2 of all texts I send end up not being able to be sent. I get an notification saying "Message not sent. Select to review the message and try again." I just end up copying the contents of the text and then trying to send it in a new one. I have 3 bars for signal showing in my apartment, so that shouldn't be the problem, right? I'm at a loss for what to do.
Any help or suggestions would be greatly appreciated. I don't have a lot of time to work on my phone at the moment though. It's the week before finals for me. Sorry that this is so long. I just wanted to get any relevant information in here.
