Unbrick Tool and Stock ROM of w719
Flash Tool : Download
Flash ROM : Download
Note:
This tutorial is only suitable for the mobile which has been bricked
Warning if phone normal do not flash
Step 1: Preparing Tool
1 driver
2 tools
3 Flash ROM Pack
In Windows 7 system, connect the mobile, it will automatically download the relevant driver.
Unzip the ROM into the directory.
Step 2: Start
1 Turn off your mobile phone
2. Pressed volume + and power button
See the screen change, the phone green screen appears after the first release the power button and volume keys. In this case, the very top of the green screen display Fastboot, In this screen connect phone usb to computer to ensure normal drive.
(Win7 will automatically to install driver, For xp manual install)
Now run AP tools QUALFAST1.0.7.exedownloaded earlier, If you can not run, vc runtime installed vcredist_x86.exe
Click the "SEL PATH" button, find the AP file path (ROM), click the OK button.
Make sure FORMAT is ticked.
ROM Flash will complete and display the finished in totaltimes
  • Like
Reactions: sanu bhai
BEST TECH IN 2023
Smartphones
