Root Unrooting Rugby Smart
kemonine96
Member
May 17, 2012
76
24
If you are trying to unroot the Rugby smart you should only need to delete the following files
  • /system/app/Superuser.apk
  • /system/sbin/su
You can delete these files with a normal terminal emulator on-device or via adb shell. The necessary commands from the command line:
  1. Uninstall any Super User updates using the Market / Play store
  2. su
  3. mount -o remount,rw /system
  4. rm /system/app/Superuser.apk
  5. rm /system/sbin/su
  6. reboot
BEST TECH IN 2023
Smartphones
