Root v5.1.1 GamerROM 5™ v1.4 BETA Updated: 12/29/15
D
Deleted User
Guest
Welcome to GamerROM 5™ the workds most popular OS from the Samsung GALAXY S4 Is now coming to the Samsung GALAXY Exhibit SGH-T599N
Features:
• OS Powerd By Omini
• Updated Android Webview
• Fast and sleek UI DESIGN
• Gapps pre installed
• AdAway Ad Blocker
• GamerROM Online™ Connection
Download: https://gamerrom.jimdo.com/samsung-galaxy-exhibit/
NOTE: allow 10mins or less to boot this only happens on first time boot as well does NOT come rooted before rooting install os first then let the os boot first then reboot to recovery to install superuser, we encounted some boot issue when you install root before letting the os boot fully first.
OS ONLY SUPPORTS MODEL: SGH-T599N
Current Bugs:
• Lockscreen and notifications may show a black solid screen but its not a big issue
• Some apps may not take advantage of the material design where the notifications changes color to the apps scheme
CHANGELOG:
• Redesigned The Gallery App you can now Sync your google and fb photos etc
NOTE: to fix the material design bug u can go into Settings>Performance>Advanced>Force High End Graphics this will fix the material design after you rebooted
We also recommend to DO A FULL FRESH CLEAN INSTALL TO AVOID PROBLEMS
Hi I tried to install your rom but every time I get an error saying this package intended for codinalte not
for condinamtr is there a work around for this or am I doing something wrong
Whats ypur model no.?
I sucessfully flashed the rom but the system ui is messed up sorry to say .. and there are alot of bugs in the rom.
WhaT modrl did you install it on currently this only supports SGH-T599N and i updated tge os today DEC 25TH
This rom works well ? If you record or still green as the CM12 '
That i havent tested i have tested if ypu do a video recording through camera at hi res it causes vidro to be green but lower the res can help
I haven't tried 1.4 but in 1.3 at least, if you don't enable High End Graphics, your notifications do not display correctly. I just noticed nobody has mentioned it.
I have mentioned it, its in the thread where you have to enable it to fix the issue im stil figuring a line to keep it enabled
Your clicking a ad that shows up on the site ive tried it without adaway just let the page load
Bug
Found when turning the flash light on using the notification drawer, you are unable to turn the flashlight off. You have to reboot the phone.
I'm not using adaway either and tried everything , still same thing.....wait edit...I got it had to use chrome....I like its more like slim and thank God finally some layers...the recent apps cards are transparent accept the header of the card so its functional just funky looking... And I gots to get an omniswitch apk kickin somehow for the regents...also be cool if it had all the nav bar capability like slim lp , a customized nav bar tweaked out just looks too cool and though not necessary with hardware buttons still just cool to play with... Lot's of lag typing in the browser especially and overall lag in the browser but so far its not bad good job guys...
