Root [Verizon] How to reflash stock rom?
androidb
Mar 3, 2010
117
11
Hi, I just purchased a used Galaxy S3 that is rooted with a custom rom. Could someone tell me where and how to go about putting the stock rom back on it? I am familiar with rooting Android devices and flashing roms, more specifically Motorola devices, and back in the day the HTC Droid Eris. I know on the forums here people used to have downloads to the stock Moto SBF files and I could use RSD Lite to flash back to stock. I was doing some searching about how to flash the GS3 but I am a bit confused. Thanks in advance for any help!
Upvote 0
Do you want the rooted stock rom, or do you wish to completely unroot to a stock rom?
Stock, rooted rom--
http://forum.xda-developers.com/showthread.php?t=2332840
To unroot and go back to stock, install this via ODIN:
http://hotfile.com/dl/182822657/9f6...WBLK3_381038_REV09_user_low_ship.tar.md5.html
After you do the ODIN thing, you can update to the current MF1 via OTA updates.
Now, if you want your flash counter reset to 0, see this guide, post #2:
http://androidforums.com/verizon-ga...ot-root-list-utilities-roms-kernels-more.html
Upvote 0
BEST TECH IN 2023
Smartphones
