All of us who have been around the android block more than once know it takes about a half a day to restore your device to the way you had it before performing a wipe.
I'm going to vent here a little. I don't see this is as a "major update." To me, a major update is upgrading from one OS to the next, like going from Gingerbread to ICS or from ICS to Jellybean. An update of this type should simply NOT require the ass pain of a factory reset. I've received several updates to my Asus Andriod tablet and they have all worked just fine without the need for anything other than a hard reset. I've had this phone for less than a month and am already starting to get tired of the idea of needing to perform a factory reset for a minor update.
All of us who have been around the android block more than once know it takes about a half a day to restore your device to the way you had it before performing a wipe. It simply shouldn't be necessary.
Though it wasn't a change from one OS to another, chances are this update did update the framework quite a bit in order to re-enable a setting Google had and then got rid of. Those types of changes tend to require resets. I don't know how experienced you are with custom roms, but rom developers strongly recommend resetting every time you flash one, even if it's an update. Not doing so can create problems, and taking an ota is no exception.
