RedHotLama
So i followed these instructions to root, http://androidforums.com/verizon-galaxy-nexus-all-things-root/474570-how-manually-root-unroot-restore-more-vzw-samsung-galaxy-nexus.html#post3736596
And it says that recovery will only be temporarily installed.
So i followed the other instructions to install CWM, but its not sticking either. http://androidforums.com/verizon-galaxy-nexus-all-things-root/474570-how-manually-root-unroot-restore-more-vzw-samsung-galaxy-nexus.html#post3736600
I tried the ROM Manager but it fails to install it. Then the other instructions are the same as the root instructions.
I also cannot rename the recovery-from-boot.p file. I can't turn on root explorer in ES File explorer and the mv command doesnt work in windows.
Any help? When i try to boot into recovery i just get the droid with red !
