Not sure if it's the same for the Attain 4g but my phone can switch from silent to vibrate mode by turning down the ringer volume. And I have a widget that toggles silent and vibrate mode. If you don't have a widget like that, try searching the play store.
that doesnt work /:
So a widget toggle doesn't work on your device. Darn it. Sorry.
To disable vibrate from your text messages you have to go into your text message settings by hitting text message>menu>settings. There should be an option for vibration in there. Took me a while to figure this one out as well.
Go into your text messages like you're going to send someone a message. Hit the menu button. There should be a window that pops up and "settings" should be an option. Go in there and you should be able to fix your problem.
