Are you writing them to see if they will make a bluer case just for you?
I'm pretty much convinced at this point that Seidio is crap.
gobludejd, does the Seidio active fit into the Innocase II holster? Active looks thicker so I'm guessing probably not.
Will the active fit with a 1500 mah battery?
I was actually shopping for cases today since I just got paid. I was looking at the Seidio Innocase II, and decided I'd do some research on it first, and of course found your thread.
My only concern is the snapping of the two pieces together as you showed in the video... I was curious if anyone else has had this problem as well out of the case. Also, I've had two piece cases similar to this one and I've had problems with dust/grit getting in the case and the small movement causes pits and scratches in the phone. Has anyone had this issue out of this case as well?
I'd appreciate some input.
I have had several of their Inno II's for my BB Tour and BB Storm and never had the problem I am having now. They are sending me a new case.
I would not worry about it and just get it. They are good about defective items. And allot of people with this case are NOT having the problem I am having.
How is the front of the case? Does give the screen a little protection if you were sit the phone down on it's face?
I have the Inno II right now. Having some issues with it and thinking about exchanging for the Active.
Active case looks nice, but I'm still holding out to see what Otterbox's Commuter case will look like. Will stick with my high gloss rubber for now. Thanks for the video reviews!
