I'd like to first thank everyone that's contributed to this forum. There are undoubtedly many lurkers like myself that stumble across it and are helped tremendously. You guys are a godsend.
My phone is rooted and I've followed the steps in TeachMe's swap and Link2SD guide. I recently repartitioned my SD card because it didn't seem like the ~3.5 GB I'd set aside for apps was enough. This time I made the first partition 24GB and left the remainder for apps. This is what Link2SD's Storage Info tab shows now:
I take this to mean I have almost 2.4GB left for apps. But I continue to get the insufficient storage error when I attemp to update or install most apps. When I pull up the Storage tab under System Settings, this is what I see:
According to this, my apps are already taking up 5.56 GB, which would explain why I'm getting the insufficient storage error--I am in fact out of room. But if this is accurate I should have run out of memory long ago. As I mentioned above, the first time around I set aside only ~3.5 GB for apps.
Can anyone explain what is going on? I've tried clearing my cache, deleting my dumpstate/logcat and other suggestions like the one in this thread: http://forum.xda-developers.com/showthread.php?t=2443267. (I couldn't find any app-lib directories so I deleted what I felt were the appropriate folders and files. Didn't work.)
I am prepared to repartition my SD card again if that will solve the problem. I am also prepared to uninstall some apps if the Victory's limited internal memory places a ceiling on the number one can have. I have far more than I need. Isn't swapping and linking supposed to effectively remove any ceiling, though?
Thanks in advance for any help anyone can provide.
