MopedRyder
CURRENT STATUS
***Note - your warranty is now void. If your phone dies, its on you.
This is a continued work in process. This version was built for the universal lte builds most ROM builders have moved to.
Currently we have working 4G LTE with both MMS send and receive working on CM / AOSP ROMs via Hangouts and stock MMS with mooknightus fix. This fix is to achieve 4G/LTE connections. Stock MMS requires the fix by moonknightus (Thanks to him) for the stock MMS fix.
This mod will:
1. Search and edit appropriate lines in build.prop
2. Reset the telephony databases (first boot will take a few)
3. copy + correct apns-conf file
4. Add / update the eri.xml file
Directions:
Flash ROM
Boot up first - reboot recovery
Flash Fix
It may take up to 5min to connect
profit....
Starting with 4.4.4 ROMs I found that you may need to boot first after flash, then go back into recovery and do the fix to take hold.
First boot may take a few minutes to bring up 3G/LTE symbols and get internet connection. The telephony database is being rebuilt - give it a few minutes. If you get an acore type error then try to flash ROM, boot, then flash APN fix.
OFFICIAL CURRENT MOD
Universal LTE builds APN FIX - Version: R2
"Universal_vmu_ApnFix-v.R1.zip"
MD5 of R2 fix:
162FCE4773D279FE37D078F09373AE37
DOWNLOAD HERE
FOR STOCK MMS FIX GO HERE:
http://androidforums.com/virgin-mob...root/865974-aosp-stock-messaging-mms-fix.html
Thanks to moonknightus for the stock MMS fix
FAQ's in the 2nd post.
Folder with all builds here [CLICK]
Special thanks to:
junkie2100
punkmaxx
moonknightus
struckn
This mod will:
Directions:
Flash ROM
Flash Fix
profit....
MD5 of R2 fix:
DOWNLOAD HERE
Special thanks to:
junkie2100
punkmaxx
moonknightus
struckn
