JerryScript
Android Expert
Thanks to rbheromax's flash of brilliance,
we now have a stock recovery img from the MG5 update!
Here it is in three versions for installing by the method of your choice:
To become as close to pure stock as possible, restore g60madman's stock backup and then flash the above recovery, (optional, then flash the MG5 update).
- Install from adb or terminal: recovery.img note - flash_image binary required:
Code:
flash_image recovery /<path_to_recovery.img>
- Install by flashing in TWRP or CWM: gogh_MG5_stock_recovery.zip
- Install by flashing with Odin: gogh_MG5_stock_recovery.tar
WARNING: You cannot flash all custom zip files with the stock recovery!
