Hey all, need some help here. My XT926 phone is running Android 4.4.2
My Razr HD's sound is loud and clear for music, notifications, ringers and alarms. So, it seems my speaker hardware is good. But my phone call earpiece volume and my speakerphone volume is way too low.
I have tried going in to the Settings/Sound and found that there is no adjustment for Phone Call volume. Nothing I changed there affected my phone call volume.
I tried a couple of apps. One, Smart Volume Control, did have a Phone Call volume slider bar. It was then I realized when I tried to change the slider for phone call volume, nothing happened. Then I tried the volume rocker during a call and nothing happens. I can barely hear my earpiece when I receive a call. The other app did not affect the phone call volume at all. Once again, all other sounds are loud and clear and respond to the volume rocker??
I also have turned off the Enhanced Privacy Setting as some forums have suggested without any change.
I also read about changing the 04 VOCODE setting in the hidden menu, but this version does not have the 04 VOCODE, I was able to get to the hidden menu with the app AnyCut. It seems it might have some effect, but also might make the phone unusable in certain regions.
Anybody have any idea of what else to try? I have only had the phone a couple of weeks. I purchased it on Craigslist. I don't remember if the volume rocker was working when I first got it.
I decided to ask in this forum for other ideas before resetting to factory and re-starting troubleshooting from there.
Thanks for any help.
