Hi Guys,
Ive had this issue for a while now, basically the voloume up button doesnt work, the down button is fine so if i want to turn it up i can press down then turn it up using the slider on the screen.
I researched this a while ago and found a bit of info about it being a software issue and not a broken button and tried what i read, which was mess about with the camera and then use the button and heypresto it sarted to work again, however this trick doesnt seem to work now.
Is this a common issue?
Is there maybe an App that is causing it?
Any info would be greatly appreciated
