Hi there, had a problem with my one x+ at the weekend were the phone totaly ran out of battery, I tried charging it straight away to no avail, tried a hard reset and nothing wouldnt boot up or anything, tried it without the sim as well which was a no go, so I was thinking my phone was dead from what I was reading on the one x forum, at a last gasp atempt I left the sim out and put the carrier back in, then plugged it into my computer, hey presto I had a red flashing red light, which I understand is the the battery very low indicator, so from some other advice I found, I quickly tapped the power button a few times and the phone booted up, I left it on charge which took abour 9 hours, (usually takes 3) but instead of an orange light when charging I get a constant red, so when I got home from work yesterday I thought Id put it on charge from the wall plug, it wouldnt charge, thought bugger maybe theres a problem after all, when I attempted to charge from the pc, it came on red solid again and started charging, so i thought Id do a system restore to see if that would sort the charging from the wall and the red light, so I did a restore and now it charges from the wall socket, but still with the red solid light, is this a problem I have with the battery, as on HTC's website theres no mention of red light, only had the phone a couple of months and its been great, no problems except this, so is it worth me taking it back to the shop or is this normal, any help would be appreciated, many thanks!!!!
Great forum by the way been a long time lurker
