Root WiFi issue[SOLVED]
pyro_guy0001
I been having issues with WiFi it turns off by it self. Been doing this for 2-3 days but now seems to work but I want some feedback.
[I HAVE CONNECTIONIONS OPTIMIZER DISABLED]
Was on kRom LV.4
Now on kRom LV.5
Seems he fixed it or a random WiFi issue I have/had.
I believe if you disable WiFi optimizer, then the WiFi will not automatically turn on and reconnect after being disconnected. The optimizer is what's turning it back on automatically.
The main issue I see with the optimizer, is it cutting on when I don't want it on. But if I turn off the function to alert me when WiFi is available then it only comes on when I come in the house, so I turn off data
Yea my gf's phone been weird sending me empty MMS messages and I'll try to download. WiFi be disabled and should turn on. But they don't work. But it does turn on after receiving MMS message
