I have a problem that is also my wifi ..
I never "forget wifi" my home. and when I find my wifi back ..
not found. please help me ..
Is your phone rooted?
"rooting" is gaining administrative access to your phone's file system. If you don't know what it is, then I doubt your phone is rooted.
Can your phone to connect to other wifi networks other than your home network?
Yes.. i can connect other wifi, but not my wifi.. because i was foget in my wifi..
can you solve that..
If you "forgot" your wifi network, just go to menu>settings>wireless & networks>wifi setting and you should see your home network listed. Tap on that and choose "connect to this network." If yu are saying you forgot the security passphrase for your network, you will have to log into your router and change it to something new and then use the new passphrase to log on.
that mean i should change the router password. ?
my problem is, my phone cannot scan my wifi. but other wifi i can connect..
Is anything else able to scan your wifi SSID?
