Wifi on/off to conserve battery
Mark1987
Would turning wifi off make a big diference in battery life while the phone is not being used in my home? I just want to conserve my data usage as much as possible.
Unless you change the WiFi sleep policy in the options, the WiFi is set to sleep when your screen is off, so it wouldn't be using battery unless your screen is on.
Thanks for the info, how do I get to the wifi sleep options?
Edit: Nevermind, I found it under advanced in the menu.
