with a full charge battery in STAND-BY, it takes just about 3-4 hours for battery to be empty! help!
reza
i got this problem recently after installing a bunch of new app,till this point with all app & wi-fi on ,it took about a day to recharge,when i used my phone with all functions, but now:
i uninstalled most of those new app,i turn wi-fi,gps,3g off,kill all background tasks with task panel,even so,with a full charge battery in STAND-BY, it takes just about 3-4 hours for battery to be empty! any solution please? i can't use my phone in real way any more because if i brows internet or use any app it is gonna empty in less then 2 hours,battery app tell me battery has excellent health too,help please?
the only new app that i didn't uninstalled is battery widget itself,could it be the source of this problem?
the other change i had were:
i gave quick access(show application in notification bar) for "toggle setting" & "task panel".
Try downloading an application called Spare Parts from the Market. It allows you to review phone usage statistics - stuff like which app did wake your phone from sleep the most, which used most CPU cycles. Same for GPS, network, sensors... It might help you identify the culprit. It's most likely one of the newly installed applications.
i have spare parts,but i never used those function,i will try them now,thanx for tip!
i uninstalled "battery widget" app now,wait to see result,spare parts give me cpu usage very ordinary:
android system-android process-task panel-touch flo-toggle setting & so on,nothing extra ordinary in my non professional opinion!
Are all of your accounts sync'd happily, I had massive battery drain when my calendar could not sync, and was constantly trying.
I guess i found the reason for this problem,i had my system trying to download some other app without success,but download process was working continuously, i cancelled those apps,waiting for better battery life now,in other hand i ordered second set of battery too!
HTC Hero 130 accu (1550 mAh) for 24 euro!
