Just got a Scroll Excel 7" ICS tablet (same OEM as Coby) and the aspect ratio is wrong. It's a 15x9 display stretched to fit a 16x9 screen.
Is there any fix for this? Can't see anything obvious in 'settings'.
If you want to check your own screen, browse or d/l a pic of a circle, zoom up to fill the screen if necessary, and measure the circle horizontally and vertically with a ruler. The two values should be equal, if not, the difference will aid finding the fault.
