Help Your current location is temporarily unavailable, Atrix 4G (MB860)
Dear Madam/Sir,
Hello,
I buy a new Atrix 4G MB860 Unlocked 3G, from Amazon.com, but GPS not work, for example when I try google-maps, show me:
"Your current location is temporarily unavailable"
Note: I turned-on the GPS in location&security
Android Version: 2.3.4
I try Navfree and Sygic, have same problem.
What can I do?
(best regards,
Alex)
Dear Madam/Sir,
Hello,
Thanks for your interesting to give me guidance.
I have the exact same problem, that you indicated in the link. [http]:[//]androidforums[dot]com/atrix-4g-support-troubleshooting/401171-gps-function-wasted-after-2-3-4-update.html#post3112766
(please remove '[]' to get the l!nk above.
Rarely GPS works and mainly not works, as people have the same problem in the l!nk above that you send.
What is you suggestion, as in the l!nk there is no solution is provided?
I calibrate compas, it cause rarely fixs in GPS functionality(1/100)!
(best regards)
Dear Madam/Sir,
Hello,
Thanks for your interest to support me.
I have a question, as I use Motorola's original ROM(never flashed and few months that I buy this new Atrix4G), as I need to install 'different radio' too? where can I find new radio software?
More descriptions:
[1]My network: 't-mobile(EE) simcard[signal strenght ~ '-87 dBm, 13 asu')'.
[2]My system version: '45.31.0.MB860.AsiaRetail.en.03'.
[3]Model number: 'MB860'.
[4]Android version: '2.3.4'.
[5]Baseband version: 'N_01.100.00R'.
[6]Webtop version: 'WT-1.2.0-133_38'.
[7]Kernel version: '2.6.32.9
e13392@zch68Inxdroid46#3'.
[8]APflex version: 'GAS_ASIA_USAOLYGBSEARET_P011',
'GAS_ASIA_USAOLYGBSEARET_A003'
'GAS_ASIA_USAOLYEMSEARET_M001'.
[9]Build number: '4.5.2A-74_OLE-31'.
[10] My Atrix4G is full Unlocked from factory(GSM&3G).
[11](more info about my own location: I live in United Kingdom/London and buy this Atrix4G from Amazon.com-> USA branch.)
Best regards,
Alex
