‌‍jio Hi-Fi speed only for rooted devices
bobby TECH
Hi friends, if you are facing the problem with jio very low internet speed inside the house, so you are in right place.
Just follow the instructions carefully and you will get right internet speed inside your home.
Jio sends signals in different bands like-
850
1800+ and
2300
likewise.
850 frequency band has good network coverage but internet speed is very low.
1800+ and 2300 frequency band also have good network coverage but not better than 850 band but have good speed of internet.
When we are outside of the house the mobile starts talking signals from the 2300 or 1800+ Hz band because of good network coverage but
When we move to the home inside because of network coverage issue our mobile switches to 850 hz band that's why internet speed gets down.
Now what??
if we manually choose the band in mobile, it will not switch to another band.
Ok, so how it will be possible??
Required fields.
1. Your device must be rooted.
2. Nervelocity app.
3. Network signal app.
How to do this???
Follow the video link below-
Thanks for sharing this tip...I will use it on my smartphone..
Can I ask what your connection to the website you've tenuously linked in every post you've made today is?
Posts made purely for the purpose of getting a link on the web are generally considered spam.
(Edit: this was commenting on a post that has since been deleted, so can be ignored).
The Phone as it is and as it comes by default already has the best signal will ever have..I started playing with those buttons you suggested and what it did was making the signal poorer..so my friend what you are trying to do is promoting an useless app..sorry, just being blunt in here.
Good luck with your app any way.
