‘Disable Absolute Volume’ missing under ‘Developer options’ on Sanyo Android (Oreo) TV
I have a Sanyo XT-43A081U LED TV running Android Oreo OS. I have a set of AirPods that I paired with the TV’s Bluetooth without any problems. But the volume is very low, almost mute despite of increasing the volume level to 90/100. After searching around, I found a common solution to turn on ‘Disable absolute volume’ under the ‘Developer options’ menu of settings. Although I have enabled the Developer options, for the life of me, I just cannot find the ‘Disable absolute volume’ option under it. So can anyone please help me unhide/enable this option for me so that I can fix the low volume on my AirPods connected via Bluetooth to this TV? Please note that the AirPods work just fine with my iPhone 6S with no problems with the decibel levels. Thanks in advance.
