Help 1 Click dialing from an Outlook Calendar Appointment
Chattrbox
I have seen this discussed in brief before, but haven't heard if there was a work around for the Outlook calendar end of things.
As has been mentioned in this thread: http://androidforums.com/samsung/565266-dialing-calendar-appointment.html
There seems to not be a way to enter the number in Outlook in the location part of the appointment like I did for the Droid 4. The S3 isn't picking up on the "1 touch dialing" aspect of the number with an extension or pin code.
I did try to enter the number as 3012221234;1234 into outlook (as it would become if you use the handheld "add wait or 2 secs button" on the phone) but it wouldn't recognize this from Outlook at all.
I tried all the tricks I know that used to work on the Droid 4 (Phone: 302-222-1234 Pin: 1234) and what worked on a blackberry... etc. Nada.
Is there not a way to pre setup the appointment with a format that the phone would recognize to do this 1 touch itself?????
Thanks in advance for the help!!
Chattrbox
