I have a behold but since its a tmobile phone and you have tmobile, I can teach you a trick. You can have them switch the data plan for unlimited texting for $10 and this $10 txt plan is separate from the family txt plans but you can also trick them and have it switched to family txt plan if you wish (after a month). They'll tell you that you shouldn't do it cuz it'll make your phone disable typa thing. But that won't be a problem if you have wifi access. Me (with the Behold II) and my friend (with the Cliq) have done this and it works fine. They'll tell you that its not possible cuz its a smartphone and it lose all of it's features but tell them that a friend of ours with the cliq did it. The only thing you lose to the ability to get internet everywhere which, in my opinion, is slow as F-word....
