ive read opinions from different sources.. they usually tend to tell you to charge phone for around 8-14hrz when you first get it! maybe someone will have a more in-depth answer for you!
On the X10 it doesn't really matter that much with the 24hr first time charge, because once it hits 100% it turns off charging.
But the best thing you can do is drain it completely (5% warning atleast) and then fully charge it. That's what i did and it now holds power for much longer than the first few charges. (It can go for 3 days without recharge)
