oxfordmark
Member
Its out now for the G2
Wish I could join the club... :/
I've just tried out Google Navigation --> c-o-o-l
Anyone getting the problem of Facebook display pictures not appearing with contacts? And also when you add a new contact you can't link it with a facebook friend?
Why can't you?
Well had it for over a day now and find that the memory is being used up fast by the system re startig apps like Footprints, Peep and messages just after I kill the them. They just will not stay unloaded. So I have like 50m left of system memory and that gets used up fast by the other apps I use. Used to have at least 100m on the old 1.5.
Anyone else notice this, or is is not an issue I should not worry about.
If I change the date will I need to check for 2.1, if so how do I do this, or will I get a message automatically - how soon will I get message once date changed....
(Does 2.1 allow bluetooth file transfer??)
I know there are soooo many questions....
thank you
SM
Hmm, I put my month forward to August and straight away a message came up to do a system update. I did this and the phone updated and then rebooted, but it's still on version 1.5. This partial update has given me the 'System software update' menu, but when I click on 'Check now' it tells me that my phone is up to date. Any ideas on how to coax it to download the actual 2.1 update?
Well it seemed to reset itself back to the correct date after the update, but I did try putting the date forward again and then back to the auto setting, but with no luck. I'll try messing with the date again, combined with a reboot or two, later.Did you reset the time back to todays date say. Reboot and check again after?
