Using the latest 2.2.1 firmware (JPK) installed by Kies. Here is what I experienced in terms of stability
-Lots of FCs. I never had much before but its happening every couple days or more with software that was workign before
-Screen goes blank. I had this problem when I first got the phone with 2.1, it was fixed with 2.2 and previous versions of 2.2.1 but JPK has the same problem again.
-Phone freezing up. This happened once while playing a game which was working with 2.2 and previous 2.2.1. Had to remove the battery
-Did not boot. After charging up, the bootup screen with the big S remains for several minutes. Happened several times and several times in a row. Need to remove battery.
GPS is still same, takes several minutes (>5) to get s fixed position.
Quadrant score a little higher.
Overall JPK seems buggy to me, will likely go back to JPG. How about you?
