Help 2.3.6 firmware problem?
I just installed the 2.3.6 firmware update. Everything works fine but I can not pick up network coverage to place calls etc... Don' know if it matters but I am in the USA.
Any ideas what might be wrong? I put all my setting back in exactly as they were.
Few things to check, may be you forgot one of these
1) Did you wipe before installation?
2) Did you tick re-partition ?
3) Did you include a proper pit file ?
4) Are you absolute sure you ticked and added the modem file ? May be you forgot and still have old modem.
Try a re-flash or download firmware from different website. You can confirm your versions by dialing *#1234# from dialer.
