Ok, I have 2 ideas:
1. Because of the buttons I use as my directional pad and buttons, there should be an option to disable the Search key (magnifying glass), and a way to disable the Menu key (4 lines). I constantly hit them by accident with my fat fingers.
2. When you save data to the game allow the system to update the rom file, that way if you get to a save point where you can record your progress, it will save to the game rather than constantly using the save states. I know this is kind of silly, but it's the OCD in me being nitpicky.
Ok, that's all. Thanks
