2-way call recording for HTC One V
Hi,
Just switched to Android ICS with a new HTC One V after being a Nokia customer for over a decade.
I like it very much, but there's one utility missing that I used to have on my last Nokia: Two-way recording of all calls.
Can anybody recommend a reliable app for this which is confirmed two work well without issues on the the HTC One V.
I'm looking for:
2-way recording without having to use the speaker for incoming audio, automatic recording of both outgoing and incoming call, if possible also when a bluetooth carkit is used, automtically active after rebooting the phone....preferably without having to root the phone.
All suggestions welcome!
Hi. Exactly the same problem as Erasmus. Have tried the popular apps and at best they only record the other end of the line faintly with the internal mic. Would really appreciate some pointers to find out who might be working on the necessary patches to fix this, do I need to download a different version of ICS, will Rooting, flashing etc. be involved?
I'm new to this Android game so really am a bit lost. Would appreciate any pointers as my work depends on it!
I downloaded "call recorder" from the google store as pelletman suggested. It does indeed work rather well!
You have to stop recording (option in "call recorder") if you want to use the HTC One V in your car with a Bluetooth connection, otherwise you won't be heard when using Bluetooth. So you can use Bluetooth or record the calls but not both at the same time.
So "call recorder" is rather good but not perfect.
