3.5mm headphone jack problem?
dubie7006
Is anyone else finding that headphone plugs fit very poorly into the headphone jack and become disconnected extremely easily? Most headphone plugs and jacks kind of 'snap' into place and you know they're in. Mine just kind of sit in the jack and have some wiggle room and give no tactile feedback ensuring the plug is in and connected. Is this just my phone?
Nevermind. I looked on some other sites for some issues and found that I wasn't using enough force. Just have to be firm with it.
If anyone else feels like the jack is loose, just push harder.
not exactly it does take a good press though - I chalked that up to newness.
but I had issues where my case cutout wasn't deep enough to accommodate the barrel of my headphones - so I had to whittle it down a bit.
