3-g or wifi phone
i cant figure out how to input #s for skype on nimbuzz and u cant add all your contacts from the phone like fring that i could see
is there a all in one? i just want to use skype nothin else and be able to dial #s into it?
Skype will be releasing an official app soon. And it will work over wifi and 3g and it wont use any minutes.
why don't you just by the unlimited minute plan and not worry about it? or do you call internationally?
Make sure you are on a plan with the unlimited friends circle and call into a Google voice account to route out going calls. (add the google voice number to your circle)
Check out Sipdroid app. You also need a calling account like skype or an easy one I used i Sipgate. Here is an awesome blog that tells you exactly how to set it up extraneous: Sipdroid + GV = GUAVA = Free Calls and Messaging to USA and Canada --won't work on samsung moment.
To the above poster "why not just get unlimited" I get spotty service in my girlfriends house, so this would be nice. Also you can take this anywhere in the world and with a hotspot make calls.
