davidsports
Hello,
Before I posted about battery issues. I reset my phone, and it seems fine now, except for one thing. My 3G seems to use a lot of battery, especially in areas with a weaker signal.
I am thinking about getting CleverConnectivity +++Battery (or the PRO version), but I have two questions.
1.) If my 3G radio is constantly turning off and on, isn't that bad? Doesn't that wear the radio on the inside of my phone down? Or is it safe?
2.) Is there a way I can stop my 3G to stop "searching" for a stronger signal, and just seem to "accept" the signal I have and deal with it, so it doesn't use as much battery?
Thank you very much for your help!
Thanks,
David
Thanks,
David
