3G problem
arununni
i cant connect to 3g network. i have already activated 3g. but no 3G signal is displaying in the handset. plz help
Welcome to the forums!
I think that it could be network related. From what you've said, it sounds like you've turned on the mobile data on your phone.
What network are you with, where are you (in the world) and which device do you own?
Hello,
Welcome to AF. Usually this might be an issue with either of two things. As what Guide member D-U-R-X said... Your mobile network might be turn off(unchecked), if so..this need to be on(checked) for 3g or 4g to work properly. The other thing is.. This might be network related problem. You should contact your service provider for assistance if the problem persist.
Best of luck. ;)
