I just got my G2x today and am fairly new to android. I am using T-Mobile and are on their 200MB plan. Watchdog currently says I used 149.15MB of data. I left 4G on because I thought it would only use WiFi when I am connected on it. Apparently not since I should e nowhere near 150MB if I did everything on WiFi. I noticed and quickly just turned off APN. The thing is when I go into the App I get 149.16MB used but when I go to Usage by application I get a measly 106.1KB used. What's going on? I understand that the usage by application might not be "accurate" but it can't be that inaccurate right?
Also in order to use less data is there a way to turn off AdMob while on 4G or just completely.
Also I am liking extended controls but I need APNDroid for 3G Watchdog and with APNDroid installed Extended Controls can't seem to control the APN using it's toggle so at the moment I have APN widget running as well which I am aiming to get rid of.
