Help $45 cricket plan work on sanyo zio android?
iyvonneuo
I have a sanyo zio with the cricket $45 plan. But mobile web is NOT working. Do I need the $55 plan or is there something I must do?
The Zio will work fine with the $45 plan from cricket. The reason the plan is also priced at $55 is that you will get the fulltime data access you do not get with the $45 plan. The apps work only with the $55 plan. Everything else will work the same. Hope this helps.
