4G LTE Cutting in & out
lowlyworm
I have been bouncing from 4GLTE to 1X in Indianapolis constantly for the past 2 days. Good signal, -67dbm.
Anyone else having issues?
HTC Rezound.
I just lost all data connectivity here in CT.
Can still make calls....my Galaxy Nexus shows full bars (all gray). Going into market says no connection. Tried rebooting, airplane mode on/off, LTE toggle, the whole 9 yards.
If you guys do a SIM card pull + power up to that message, and then shut down/plug in the SIM card and boot..... be sure to check that the data function (Mobile Network) is enabled. Mine comes up disabled and for a moment i was wondering why i can make calls but no data LOL.
I just usually toggle airplane mode and it fixes itself. Just annoying that I have to do this. Happened again once this morning.
HTC Rezound.
Where in Indianapolis? According to their network repair bureau the Airport is a marginal coverage area.
00smurf
Same sh**, different day. :-(
Things are much better today. At least when loosing 4G, I'm not dropping all the way down to 1X. Mind you that the 3G downshifts are without a tower change and with signal levels above -70dBm.
With the territory expansions, VZW must have extra staff onhand to hold the plugs in the wall.
My 3G has been in and out the last 2 days. I'm in Raleigh, NC. I have done the *228 update roaming thing. I have done the full reboot with removing and putting back in my battery. I don't know what's going on.
