4g mobile hot spot default password
  • Thread starter Thread starter arliss77
  • Start date Start date
A
arliss77
Guest
I have the lg mobile hot spot (tether) active on my phone but to use it on anothet device you need a password so i dont know what password
Welcome to the forums!
Is this a Verizon hotspot?
If this is a Verizon hotspot, the setup is quite simple. Pull down your notification bar and select the "Hotspot activated. Touch to set up."
Then make a note of the password it gives you. Should be good to go!
