Hi everyone. I'm not that good with all this but today I received a notification on my Nexus 10 for update 5.1. I tried to apply it and it failed, I ended up with an Android logo on the back, an exclamation mark and a 'No command' prompt.
My device is unlocked and rooted, so then I used SuperSU to make a 'Full Unroot' and tried again, same message. I checked before and after with 'Root Checker' and I was rooted, after the 'Full unroot' I was indeed unrooted.
Then I tried again with OTA while not being rooted and it seemed to work, it started to 'update' in a way and then bam, Android on the back but this time, it was saying 'Error!'. So I can't get OTA updates anymore I guess.
Then I tried Nexus Root Toolkit v2.0.4, like I did when I rooted. I tried 'Sideload Update' and followed the instructions. Everything seemed fine up until I got this error message ;
Verifying current system...
"/system/bin/install-recovery.sh" has unexpected contents.
E:Error in /sideload/package.zip
(Status 7)
Installation aborted.
I downloaded the update file twice since maybe the file was corrupted from the download. I followed all guidelines, but nothing works either way. Someone has a solution?
I also have my Nexus 5 and Nexus 7 2013 to apply, I hope I don't get errors like theses. I rooted the same way for my 3 devices...
Thanks a lot!
(Status 7)
Thanks a lot!
