Help 626s cricket
how can I use my unlimited data on cricket as a local hotspot?
my phone will not allow hotspot with unlimited data..
is this a thing that can be fixed by unlocking the sim card?
please make it simple..... I am a old man lol new stuff is hard. u know like running water and flush toilets.
thanks
let me clarify - you want the mobile internet (GSM) sharimg from your HTC? If yes - that is, such an option as a "hotspot" in the settings menu. Then your phone will work as wi-fi router. If you want to get internet on the PC - yhen select the "Modem" mode (in same menu) and connect USB-cable from phone to the PC.
which of these options to tell you more?
Cricket does not allow hotspot or tethering with unlimited data. I want to use my phone data to watch movies on pc or tv. I have limited internet data available. Cricket does allow hotspot with lesser data plans. on the same phones. so it must be a software or firmware patch they put on to block the hotspot. I would like to get around that problem
Have you tried FoxFi? I think that's the usual recommendation for things like this, although I've never had to deal with carrier restricted tethering myself. NO Cricket of course.
I tried the foxfi.. it will allow tethering but still no hotspot. Thank u for the suggestion
I goooott u man. .. create a new APN exactly like the one u have u got a 70 dl plan right unlimited bla bla . Ok where says proxy u put proxy.cricketwireless.net and look online for cricket apn and put the rest of the apn type services .this I'm not sure is necessary anyways may be it is anyways switch ur apn copy name it how ever u want and while u are on it go turn ur hotspot on and will go on with. Out message . Now that u did this go back to ur apn page and switch back to ur original apn and bum u got unlimited super fast hotspot Crack this fools and enjoy ur movies or whatever porn I don't know.that u watch courtesy of spinnerfast333
