Root 64-bit?
bfldworker
Simple question. Being this phone has a 64-bit arm SoC in it does this phone run a 64-bit version of Android?
Apparently yes
http://developer.android.com/about/versions/lollipop.html
"Performance focus
Android 5.0 provides a faster, smoother and more powerful computing experience.
Android now runs exclusively on the new ART runtime, built from the ground up to support a mix of ahead-of-time (AOT), just-in-time (JIT), and interpreted code. It’s supported on ARM, x86, and MIPS architectures and is fully 64-bit compatible.
ART improves app performance and responsiveness. Efficient garbage collection reduces the number and duration of pauses for GC events, which fit comfortably within the v-sync window so your app doesn’t skip frames. ART also dynamically moves memory to optimize performance for foreground uses.
Android 5.0 introduces platform support for 64-bit architectures—used by the Nexus 9's NVIDIA Tegra K1. Optimizations provide larger address space and improved performance for certain compute workloads. Apps written in the Java language run as 64-bit apps automatically—no modifications are needed. If your app uses native code, we’ve extended the NDK to support new ABIs for ARM v8, and x86-64, and MIPS-64.
Continuing the focus on smoother performance, Android 5.0 offers improved A/V sync. The audio and graphics pipelines have been instrumented for more accurate timestamps, enabling video apps and games to display smooth synchronized content."
Ah, ok. I asked because of 1. The SoC and 2 in the desktop world 64-Bit is only useful if you need and use more then 4 GB of RAM. This phone has 3. But hey, who am I to judge about why they did it.
Well there is the argument that even putting the RAM aspect aside a 64-bit processor is faster at running through data on a large scale but yeah I tend to agree, as far as I'm concerned 'they' are in the driver's seat and we're all just along for the ride.
From my experience 32-bit phones run code as fast as a 64-bit CPU of similar specifications.
