6p won't stay on vibrate
mbarn83
I keep putting my phone on vibrate and then it magically turns back on. It's really aggravating at work when I get text sounds.
Anyone have this problem or know of a fix?
I'm having the same problem. I think it may be due to my case. It's an ADOPTED case and it's pretty tight - I notice the volume buttons are pretty sensitive with it on. Do you have a case on your phone?
Just saw this reply. It's definitely not the case. I reset my phone and it was working fine until I installed the new android N beta and it happened again.
Can you pinpoint exactly when this is happening (phone in pocket, phone on table, etc) as well as the amount of time between when you set the phone on vibrate and when you start hearing it again?
Do you have any apps installed that interact with notifications (lightflow, etc)? If you go to settings>Security>device administrators, do you have anything unexpected there?
