Root [7.1.1] [Nougat] [UNOFFICIAL] BeansTalk ROM for LG L70
Pablo Ortiz
http%3A%2F%2Fwww.romwarehouse.com%2Fscott.hart.bti%2Fgraphics%2FBeanStalk6_BeanStalk6.PNG
http%3A%2F%2Fwww.romwarehouse.com%2Fscott.hart.bti%2Fgraphics%2FBeanStalk6_Features.PNG
CyanogenMod 14 based
Quicker system animations
Trimmed down fat and excess bloat
Option to enable all widgets
Numerous extra lockscreen options
LCD Density
Custom original BeanStalk Wallpapers by skyliner33v
Custom BeanStalk bootanimation by skyliner33v
3-minit battery support
Clock and date options
Contextual Header - Original and Polygraphic
Battery styles - Includes specific colors and styles. Also includes battery bar
Do not disturb option
Show notification count
Recent screen options
Customizable navigation bar
Use Omniswitch as default recents
Slimrecents
Lots of Lockscreen customizations
Built-in screen record
Toast animations
App Circle bar
Gesture Anywhere
Disable FC warnings
Disable Immersive message
Force expanded Notifications
Configure scrolling cache
Build.prop MOD options to enable/disable tweaks as preferred
Less frequent Notification sounds options
CRT screen off/on options to specify how the animation shows
Enable/disable wake up on charge option
Superuser fully embedded into the build and accessed from settings menu
CM Performance options and features
Hide superuser icon
Developer options and advanced reboot enabled by default
Numerous cherry-picks and improvements throughout the build, baked into the
awesomeness of existing CM layout.
Numerous other options hiding throughout the build. For a full list of changes and features, please
be sure to checkout change log below.
You tell me. As of now no major bugs.
http%3A%2F%2Fwww.romwarehouse.com%2Fscott.hart.bti%2Fgraphics%2FBeanStalk6_Download.PNG
BeanStalk Rom [AFH](6TH FEB 2017)
OpenGapps
BeanStalk ChangeLogs
http%3A%2F%2Fwww.romwarehouse.com%2Fscott.hart.bti%2Fgraphics%2FBeanStalk6_Installation.PNG
* Download ROM and latest GAPPs.
* Copy ROM and GAPPs from above to internal storage.
* Reboot into recovery
* Full wipe and format is ALWAYS suggested to avoid odd issues.
* Flash ROM and then flash GAPPs.
* Reboot and enjoy the BeanStalk goodness.
http%3A%2F%2Fwww.romwarehouse.com%2Fscott.hart.bti%2Fgraphics%2FBeanStalk6_Credits.PNG
BeanStalk source can be found HERE
Carlos Arriaga
vm03
CyanogenMod
AICP
crDroid Android
Hi, been using this rom for about a week, great job! Only small issue I'm having is smartlock on body detection, it will lock instantly when put in my pocket then sometimes I'll put it down for an hour+ and it stays unlocked. By no means a deal breaker but irritating non the less! Otherwise though I can't fault it
New build, you can test if the problem persists or solved
Will do when I figure out how to save to external sd! Can only find the option in Opera but it's greyed out, these permissions are tho only thing tempting me back to kk! o_Oo_O
Hi, those permissions are app specific. There're not many browsers allowing saving files to the SD. I'm 100 % sure that Dolphin Browser can do this after selecting your SD path, but be careful - this browser is considered to collect some data without user's knowledge. I've tested it with CM13 some time ago and it did the trick.
New build, 06.02.2017
Change log can also be found from within the ROM by going into settings menu -> about phone -> about beanstalk -> changelog
Sorry for taking so long to update the ROMs, I've been quite busy and I've had some issues with my instance of Google Cloud, but these days I will update most. :)
😓😕 When I connect my mobile to the PC  after enabling ADB the my windows 10 crashes. Developer due you have any fix to this.
@leo tekgenio ,
Make your own forum research on the L70 threads
1. Uninstall the LG drivers;
2. Install the google drivers.
As far as we know. This is not a bug of all ROMs we tested.
Sorry for my noobishness. But how do I do that. I believe uninstalling of the previous driver is to be done from the device manager menu right?  Now the question I don't know is how to install the Google drivers. Could you give guide me with that Thank you.
Google Universal USB driver:
https://dl-ssl.google.com//android/repository/latest_usb_driver_windows.zip
How to Install Google USB driver
Once you've downloaded your USB driver, follow the instructions below to install the driver.
Windows 10
To install the Android USB driver on Windows 10 for the first time, do the following:
  1. Extract your driver package file;
  2. Connect your Android device to your computer's USB port;
  3. From Windows Explorer, open Computer Management;
  4. In the Computer Management left pane, select Device Manager;
  5. In the Device Manager right pane, locate and expand Portable Devices;
  6. In Portable Devices, right-click the name of the device you connected, and then select Update Driver Software;
  7. In the Hardware Update wizard, select Browse my computer for driver software and click Next;
  8. Click Browse and then locate the USB driver extracted folder. For example, the Google USB Driver is located in android_sdk\extras\google\usb_driver\;
  9. Click Next to install the driver.
I had already installed ADB on my pc. Everytime I tried connecting my phone the Pc would crash with a particular error. So I found the file in the error and renamed it. Now everything is working well. Thanks for the response anyway members.
